This command configures the grace period sent out in Grace LSAs and used by a restarting router.
| seconds | Interval in seconds. Range is 1 to 1800. |
The default grace period is 120 seconds.
The range is 1 to 1800 seconds. The grace period should be greater than hello interval and router dead interval of the OSPFv3 interfaces on the router.
This command was first available in ExtremeXOS 21.1.
